Posted by Bob M on October 01, 2007 at 18:37:14 from (69.205.124.61):
In Reply to: lighting and amps posted by sgtbull on October 01, 2007 at 17:54:45:
Try moving the 3rd brush as close as possible to the nearest fixed brush. This will set the generator to it's maximum possible output. The regulator will then control the output current as required.
However if adjusting the 3rd brush does not help, suspect either a faulty regulator or a weak generator.
Note: A healthy generator should provide 3 to 5 amps of charge with all three lights burning on "bright" and the engine running at full speed.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
