Posted by John T on October 01, 2007 at 19:54:16 from (66.244.83.147):
In Reply to: lighting and amps posted by sgtbull on October 01, 2007 at 17:54:45:
Wow, thats a difference of like 14 (+ 8 to - 6) amps when the lights are turned on, I wonder if theres a minor high resistance short in your lighting circuit??? Have the lights on and dead ground the gennys field post with the engine at fast RPM n see what happens????? If its still - discharge (and theres no minor high resistance light wiring short), I suspect the genny is weak, may well be the brushes are worn down too short or else the brush hold down spring assemblies are weak/stuck/corroded, try to clean n light lube n exercise them and/or the commutator may be all oiled or carboned over which a good clean up may cure?? If she charges better when the fields dead grounded, then I suspect a VR problem like a faulty field current control relay or carboned n burned contacts. Id put a good direct ground on the VR also n see if that helps in case it has a weak resitive ground.
While adjusting the third brush closer to the fixed may well help, Id try the above first cuz short brushes or weak springs or a dirty commutator can cause a weak charge. Also try a good clean ground on the case of the VR and the gennys case/frame also in case its resistive.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
