Re: 1939 M Power takeoff
Posted by Wayne in MN on October 02, 2007 at 05:49:44 from (71.13.41.242):
In Reply to: 1939 M Power takeoff posted by Buck E on October 02, 2007 at 03:00:09:
You will have to drain the gear oil, pull the top off the transmission, remove all the gears, find a press to remove the gears from the lower shaft, find a new style shaft to press the gears back on, reinstall the gears, (check the bearings while you are in there) & install the top with a new gasket.
Now you can install the new style PTO. Replace the gear oil while you are at it.
Just did that on a 1940 model.
