Posted by jal-SD on October 02, 2007 at 06:19:05 from (71.32.32.172):
In Reply to: 1943 farmall H posted by dan160 on October 02, 2007 at 03:56:59:
No easy way to remove radiator. (IMHO, removing the radiator on an H is probably the most miserable job there is when restoring a Farmall.) You have to go up through the bottom of the bolster to get at the two bolts that hold the radiator on at the bottom, can't get in there with a socket, takes a wrench & you have to turn it over with each turn. (I've never tried a ratchet wrench, that MIGHT work better.) They are fine threaded & usually rusted. Be sure to get all the cotter pin out. Don't let them turn in the radiator, they'll break the solder on the bottom of the tank. Best luck I've had is to use lots of PB or your favorite penetrating oil for a couple of days before you start on the nuts. Oh, by the way, you can't see what you are doing very well either. An M isn't much better. Also, getting the height right for the steering shaft to go through the top tank when you put it back on is real a pain. (My $0.02 worth. jal-SD)
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
