That brings back memories from my early years spring plowing at night!
Even in perfect condition those generator systems were marginal for working long hours in the dark. A few things we did to help run thru the night:
1 - Douse the lights at the end of each round (eg. when traversing the headland) to give the generator a moment to charge the battery.
2 - Operate the lights on the D(im) setting when possible. This provides BARELY enough illumination to see ahead. Yet the still brightly lit rear light provides adequate illumination of the implement.
2 - Fit the shortest fan and generator belts you can find, and run the belts as loose as possible without them slipping. This permits opening the adjustable fan and gen pulleys as far as possible, thus spinning the generator as fast as possible.
3 - Remove the commutator dust band from the generator so it runs cooler. (The hotter the generator internals the LOWER it's output). This however shortens brush/commutator life under dusty conditions.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
