Re: Charge Problem Making No Sense
Posted by teddy52food on October 02, 2007 at 10:09:14 from (204.73.107.177):
In Reply to: Charge Problem Making No Sense posted by terryjd on October 02, 2007 at 09:43:19:
Do you have a battery ign distributer or a magneto? If it has a mag it will keep running without a battery. Put a volt meter on the battery posts. Note the voltage. Then start it up and see if the voltage is higher. If it is , it is charging.
