If you have an ammeter to use, unhook the BAT terminal from the regulator & using a jumper wire-- connect one end to the Bat terminal on the reg--& the other end to one terminal on the ammeter. From the other ammeter terminal, connect a jumper wire to the Neg battery terminal. Polarize generator if not already done. Start engine & note reading on ammeter. It should show charge. If it doesn't, do as Jim says & ground the field. Check for charge. I believe you have a wire or two crossed up in the magic box which houses the switches & gages.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
