Yes I have checked the wiring diragrams to make sure its hooked up right and it seems to be. Way its wired is from VR Batt terminal a wire goes to the AmpM to the post on the discharge side. Then a wire goes off the Charge side post of the AmpM to the starter. These are the only 2 wires on the AmpM. From the VR where it is marked L terminal the wire goes to the ignition pull switch. The amp meter does show discharge when lights are turned on and tractor is not running. Will take the diragram out and check the wires again.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
