Re: Converting 806 to narrow front with 560 parts, will it w
Posted by the tractor vet on October 02, 2007 at 14:53:04 from (75.19.123.107):
In Reply to: Converting 806 to narrow front with 560 parts, will it work? posted by 6780 on October 02, 2007 at 11:53:01:
One has been under my 806 for 8 years now as the org. had a bad spindle from a bearing seizing and wore into the spindle and at the time i could not find the correct one layen around but i had a spare out of a 560 and being that i was in a pinch it got bolted up under and is still there , now the one for a 806 is alot heavier then the 560 as long as ya don't hang a 1000lbs on the weight bracket and bounce it across dead farrows or drop it when ya have the ft. end hangen 5 feet in the air at a tractor pull and drop the ft. hard all i can say is as of last sat. she was still under there . As that was the last i was on it.
