Re: starting problem
Posted by Janicholson on October 02, 2007 at 19:42:56 from (66.173.50.135):
In Reply to: starting problem posted by Bill Pingel on October 02, 2007 at 19:27:43:
The starter could be dragging (I do not know what was rebuilt on yours) Go to a auto store NAPA or the like, and buy a starter draw meter that reads to 600 amps. This device is cheap and is just held against the cable to be used. If your tractor draws more than 375 to 400 amps, it needs the starter replaced, or checked by a shop that can check armature grounds and internal shorts. A starter that has been dragging will often have shorted windings from metal deflection on the armature. If the tractor engine runs well and is not tight from being very new, or from a broken ring or other disaster, the starter would be my focus. JimN
