Re: oil seal AV
Posted by gene bender on October 03, 2007 at 04:12:33 from (67.55.226.214):
In Reply to: oil seal AV posted by jmc1234 on October 02, 2007 at 17:04:03:
You did not say which seal as there is two. The one that goes to the steering wheel can be removed by taking the large nut off the front then by turning the shaft it will screw out the front. You have to remove the steering wheel. Mite want to replace the bushing also. Bottom seal the whole steering sector has to be removed.
