governor weights
Posted by Charles E. McNelly III on October 03, 2007 at 19:48:51 from (65.150.172.7):
Does anyone know the weight differance between the governor weights in the Farmall B and the power units with the same engine? I was reading the power units ran at 1800rpm. I looked it up in the service manual and they used the same spring as the tractor just a different set of weights. I figure if I were to take a little off of my weights, maybe the little tractor won't drop so much rpm when loaded. I tested the spring and it's still pulls at 15.5 lbs. at 2 1/8".
Any Ideas? Thanks,
Chuck
