Assuming an H or M or other of the same pattern, they are studs many cut them off and remove the stubs after the rad is out. If you are good with a flame wrench, heat the edge of the nut only then gently apply oxy to scarfe off the tut only. if it comes part way, let it cool before trying again, or you will cut the stud. The trick is to keep the stud below cutting temp so that it does not ignite. JimN
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
