Re: H hourmeter
Posted by RustyFarmall on October 04, 2007 at 08:14:19 from (66.43.253.55):
In Reply to: H hourmeter posted by kerm on October 04, 2007 at 07:38:35:
Possibly hooks up to an oil pressure sending unit? Another option might be the hot ignition wire going from the switch to the coil? Or it might have picked up the signal directly from one of the spark plug wires? If it used the oil pressure sending unit, then I think one of the wires on the hour meter would be connected to the battery, and the other wire went to the sending unit. I'm only guessing at this point.
