Re: Intermittent Miss
Posted by El Toro on October 04, 2007 at 09:08:46 from (205.188.116.73):
In Reply to: Re: Intermittent Miss posted by Brian Jensen on October 04, 2007 at 08:14:26:
If your engine is a gas engine the rotor will turn CW. If you start on gas and switch to diesel
the rotor turns CCW. You still leave the No1 plug wire on the cap at around 1 o'clock, but switch the other 3 wires in this order. Hal
3-1
4-2
