Re: Hydraulic Help Please
Posted by Janicholson on October 04, 2007 at 12:44:41 from (199.17.6.122):
In Reply to: Hydraulic Help Please posted by Brian Jensen on October 04, 2007 at 12:26:37:
I would make a fitting (rubber plug) with a schrader (tire valve stem) valve in it to fit the fill plug. I would remove the bleeder from the pump (put a pan under it) and put about 15 psi in the resivoir (watch the bleeder to see if things are moving. It might not need to be running. That is what I would do, others may have more help. JimN
