Re: Carburetor icing
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by IHank on February 18, 2000 at 22:33:35 from (167.142.12.58):
In Reply to: Carburetor icing posted by frank on February 18, 2000 at 22:00:38:
That is an easy fix. You just install a copy of the heated air intake system used on late 1970's cars and pickups. The "hot spot" manifold design should make things work out after you get the engine warmed up. Using an ethanol blend gasoline will also help move moisture on thru. Good luck!
Post A Followup
: Re: Re: Carburetor icing
