Re: SC WFE steering arm..
Posted by Nat 2 on October 05, 2007 at 05:32:20 from (64.80.108.53):
In Reply to: SC WFE steering arm.. posted by Keith-OR on October 04, 2007 at 19:43:13:
Definitely not original, BETTER!
The original steering arm is very thin, and cast, which means it's brittle and easily broken. On the surface at least, this one looks much stronger.
You'll have to look for an OEM steering arm at salvage yards. The ones you'll find are likely already broken and/or badly worn.
