Andy On the back of the light switch is a resistor It is a wire wraped thing. Some are mounted on a piece of Mica insulator. They get very hot and in doing so they reduce the voltage to the headlamps only. If the lights are left off for a while, dire and contaminants get on the resistor, when used they burn off. If more, or higher wattage bulbes are used in the lights, this resistor will burn out. JimN
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
