Re: Hydraulic Update
Posted by El Toro on October 05, 2007 at 15:34:53 from (64.12.116.73):
In Reply to: Re: Hydraulic Update posted by Brian Jensen on October 05, 2007 at 15:04:05:
That's for his oil pressure that's probably less than 50psi. WE used steel braided hose for measuring hydraulic pressures on test vehicles.
We never used copper tubing very much except when we ran the test pressures to a manifold on top of the power pack. Then we would run low pressure hose that was rated at 250psi working pressure to a gauge panel. We made our own high pressure hose as we needed it. Hal
