Re: compression on cub
Posted by El Toro on October 05, 2007 at 18:16:45 from (205.188.116.73):
In Reply to: compression on cub posted by Farmallb on October 05, 2007 at 17:53:23:
Are you sure the valves have enough clearance? They call for .013" cold. Did you measure the ring gap? You should have around .007" to .017" on the compression rings and .007" to .015" on the one piece oil ring unless you had the 2 rails and expander for the oil ring. You should've used a glaze breaker in each cylinder to remove that glaze from the old rings too. This gives the rings a new surface to seat in. Hal
