Re: Which control switch do I want?
Posted by Steven f/AZ on October 06, 2007 at 06:52:28 from (24.121.167.138):
In Reply to: Which control switch do I want? posted by Mike CA on October 06, 2007 at 00:21:20:
You will need the one with a single prong. The magneto just needs one wire to ground it out to shut the tractor off.
Distributor would need the two prong - one supplies power from the battery/ammeter and the other one powers the coil.
Make sure when you mount the magneto kill switch that it is grounded to the tractor well...
Today's Featured Article - 12-Volt Conversions for 4-Cylinder Ford 2000 & 4000 Tractors - by Tommy Duvall. After two summers of having to park my old 1964 model 4000 gas 4 cyl. on a hill just in case the 6 volt system, for whatever reason, would not crank her, I decided to try the 12 volt conversion. After some research of convert or not, I decided to go ahead, the main reason being that this tractor was a working tractor, not a show tractor (yet). I did keep everything I replaced for the day I do want to restore her to showroom condition. ... [Read Article]
