Re: Carburetor icing
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by HR on February 19, 2000 at 05:55:16 from (207.115.63.13):
In Reply to: Carburetor icing posted by frank on February 18, 2000 at 22:00:38:
Frank: Befor you start buying auto or pickup parts, which IHC didn't do too much of, try another new gasket at the joint you mentioned had ice forming. Also consider the air flow INSIDE that area. It needs to be smooth to prevent turblance which can change the temp just at that spot. Is a gasket restricting the air inside at that point? Could there be an air leak there too? You just may be able to clear up the source of the problem first before trying auto\pickup parts. harvey
Post A Followup
: Re: Re: Carburetor icing
