Re: Farmall A running ruff
Posted by gene bender on October 07, 2007 at 00:41:39 from (67.55.226.214):
In Reply to: Farmall A running ruff posted by B-Bob on October 06, 2007 at 18:31:44:
I would run a compression check first. Dont realy care about how high the reading is just how the readings are even from one cycl to the others.
