Re: BIG Problem
Posted by El Toro on October 07, 2007 at 04:16:13 from (205.188.116.73):
In Reply to: Re: BIG Problem posted by Brian Jensen on October 06, 2007 at 19:21:07:
Did you have oil pressure after changing the oil and filter? See if the engine can be turned backwards as Chuck suggested. If its the timing gear it will still involve a good bit of work
just to get to the timing gear. You will need a good manual that covers the 450D. If you decide to tackle this you need to take notes and pictures
during the teardown. Hal
