The 400-450 heads Do-not have a fitting in the back of the head ! The tube under the valve cover is cut off and is only 6" long .
You need a valve cover off a 400,450 they have a welded in fitting so you can conect it to your air clearner. You can weld in a fitting into yours and put a hose barb in it and run a piece of rubber hose .
I put a 450 gas head on my "M" this year and i found the correct valve cover on ebay for $20.00 I also tapped a hole in the intake manifold and ran a hose from there to the valve cover insted of the air cleaner . [PVC] Works graet keeps moisture out of the motor .
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
