Posted by RustyFarmall on October 07, 2007 at 10:20:13 from (66.43.253.55):
In Reply to: carb headache posted by e-manhunt on October 07, 2007 at 06:13:43:
First let me say that if you are not comfortable or knowledgeable about working on carburetors, please let someone else do it for you because there are a number of things inside that carb that can easily be damaged by an inexperienced tinkerer. Having said that, I will tell you that apparently your carb has sat for quite some time with gasoline in it, and that gas now turned into a sticky gooey mess that has caused the needle valve to stick shut and possibly has also caused the float to freeze up on the pivot pin. The only long lasting cure is to take it off the tractor and give it a thorough cleaning.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
