Re: Farmall A running ruff
Posted by Janicholson on October 07, 2007 at 11:00:08 from (66.173.50.113):
In Reply to: Farmall A running ruff posted by B-Bob on October 06, 2007 at 18:31:44:
If Gene's results are OK uniform compression of about 90 or more psi, the next thinking is timing. If it has a Mag (not points and coil/distributor) the roughness might be somewhat normal. Adjust the mixtures at both idle and high speed to finess the mixture (A look at the parts layout caseih,com search for parts, is a good place to start for the location of adjustment screws. The archives here also detail how to do it. Carburetor adjustment. A distributor will adjust spark timing to engine speed. JimN
