Re: Supper C generator
Posted by Bob on October 07, 2007 at 13:22:14 from (69.178.229.154):
In Reply to: Supper C generator posted by Larry in GA. on October 07, 2007 at 12:51:54:
When charging, the "A" terminal will read in the -7.0 to -7.4 Volt range TO GROUND.
As long as you are seeing this voltage, the voltage measured between the "A" and "F" terminals is IRRELEVANT.
With a properly-functioning generator, the harder it's charging (output AMPS), the LOWER the voltage to ground on the "F" terminal will be.
