Super C thanks scottyHOMEy
Posted by Larry in GA. on October 07, 2007 at 19:08:03 from (75.117.182.56):
Scotty
I forgot to mention that mine has the fast hitch and also the auxiliary control valve. I didn't realize that there is all most no room between the pluming for the valve and the starter. Never paid any attention I guess. I was able to get it back enough to roll it and get at the last screw. I cleaned it up. It didn't look bad to me we will see. I guess I should try and clean up the mating surface between the starter and block while I have it loose too.
I went a head and checked the generator and it was only reads 2.3 volts between A and ground so I pulled it and will take it and the switch in to town tomorrow. thanks for the help.
Larry
