Re: c-123
Posted by Hobo,NC on October 08, 2007 at 05:08:38 from (71.30.105.105):
In Reply to: c-123 posted by iowa100 on October 07, 2007 at 20:10:21:
My 100 did not have"em either, nor does it have lock"n retainers now. A drop of loctite will hold"em. When you install the rear seal upper and lower plates spray some soapy water around the out side and use low air pressure and a blow gun and check for leaks. I seal"em with good automotive gray silicon, also seal the front cover to with it. The covers git bent and dis sorted and hard to seal up.
Fire crater pistons will wake it up, a late 140 head and cam will turn it into a beast.
