Posted by mkirsch on October 08, 2007 at 09:10:22 from (64.80.108.53):
Hello,
Would a small leak around the oil filter cap on a Cub engine cause the oil pressure gauge to read low? Either the brass washer or the gasket was no good, and it's been leaking a little since the last oil change.
Since I got the tractor two years ago, the oil pressure needle has only been going up to between the second and third line (10 o'clock position, roughly). I replaced the brass washer along with the filter and gasket yesterday when I changed the oil. Once the tractor built oil pressure, the needle went straight to the 12 o'clock position.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
