Re: Worn wheel spindle threads
Posted by Owen Aaland on October 08, 2007 at 14:12:22 from (65.174.247.81):
In Reply to: Re: Worn wheel spindle threads posted by Janicholson on October 08, 2007 at 12:06:39:
In addition to the split nut with the pinch bolt, there is another style that is a two pice nut where the first nut screws on the spindle and then the second nut screws on over the outer end of the first one. The first nut is split on the outer end so that when you screw the second nut on it forces the first one tight in the spindle threads.
