A possible alternative is a Ny-lock nut with red Loc-tite on the threads. You would have to leave the front end on a jack until the Loc-tite had time to set up. Another possibility is a jam nut on the outside of the replacement nut to be on good threads. Option C is rather drastic---but has worked on two situations with the worn thread thing. Turn the nut tight enough to get the bearing adjusted right---then weld the nut to the spindle in two places.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
