Re: Cub Brake bands
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Farmer Bob on February 19, 2000 at 11:07:23 from (207.227.187.100):
In Reply to: Cub Brake bands posted by Bob G. on February 19, 2000 at 04:48:43:
Bob G., From one who has just replaced the bands on my '64, here's some ideas. I had to remove the drums from the shafts and have the drums turned about .040" to get the new bands to fit and still allow some movement for setting the proper tension (pedal free play). They are still tight but will loosen with use (wear). At the pivot points where the bands attach ensure the rivots are clean (no rust). Someone else recommended shaving down the new brake lining with a drum sander but I didn't do that. Good luck with those brakes.//FB
Post A Followup
: Re: Re: Cub Brake bands
