Re: Farmall Regular Carburetor
Posted by russs hamm on October 09, 2007 at 13:41:15 from (63.245.179.200):
In Reply to: Farmall Regular Carburetor posted by JohnG(TX) on October 09, 2007 at 11:04:56:
The stem that goes through the center can be a problem, some are rusted to nothing at the bottom and some break off when you try to remove the nut on the bottom end. Otherwise, they are more or less a mixer, make sure all the holes are open. The float and needle/ seat are available if needed. Adjust the main screw on the top at one and a quarter turns out and the idle screw underneath at a quarter turn out, that should start it with one choke. After that, throttle open and turn the top till it sounds right, idle adjust the bottom. Seems like most times the idle adjustment doesn't change much of anything. I had a four cornered needle the other day that stuck in the seat bore once in a while. Sometimes for float adjustment i will plug the hole in the bottom of the bowl with a washer/bolt/ rubber seal affair and hook the gas line right up to the inlet with the top off. You can adjust the fuel level really well this way, and check the needle/seat and float right then before assembly.
Today's Featured Article - A Lifetime of Farm Machinery - by Joe Michaels. I am a mechanical engineer by profession, specializing in powerplant work. I worked as a machinist and engine erector, with time spent overseas. I have always had a love for machinery, and an appreciation for farming and farm machinery. I was born and raised in Brooklyn, New York. Not a place one would associate with farms or farm machinery. I credit my parents for instilling a lot of good values, a respect for learning, a knowledge of various skills and a little knowledge of farming in me, amo ... [Read Article]
