Re: 12 Volt Conversion Done- One problem
Posted by Bob on October 09, 2007 at 14:32:15 from (69.178.229.154):
In Reply to: 12 Volt Conversion Done- One problem posted by terryjd on October 09, 2007 at 13:21:12:
You've either got a poor ground, or a high resistance connection somewhere between the alternator's output stud, the ammeter, and the battery post. Check the voltage at each of those points. Does it vary significantly from on test point to another?
(If you used a 12-Volt generator, the above still applies.)
If all that checks out, the alternator may have a bad diode in it's bridge rectifier or diode trio.
