Re: Farmall 656 Diesel - 1966 - Power Steering
Posted by the tractor vet on October 09, 2007 at 17:51:29 from (75.19.126.134):
In Reply to: Farmall 656 Diesel - 1966 - Power Steering posted by Shawn Alfonsi on October 09, 2007 at 17:35:36:
With out the proper test equipment or at least a high pressure gauge your spitting in the wind as it could be something simple like a stuck valve that could be cleaned up or a pressure reg. stuck open . Working on Hyd.'s is like tryen to work on a new car or truck with out a scan tool. If you don't have the basics of hyd.'s ya may be ahead of the game by having someone that does run a check on it and then repair or replace what is wrong . Running a flow rate on the pumps will tell fast if it is the pumps.
