Re: Farmall Super C governer
Posted by gene bender on October 09, 2007 at 18:35:52 from (67.55.226.214):
In Reply to: Farmall Super C governer posted by Ben Milliken on October 09, 2007 at 17:45:52:
I rebuild them as the S,SC,A,B,and BN are all the same. Its a close fit but it will come out just by removing the bolts. Now if the input shaft is worn and sloppy it needs a new bushing installed by using a 1/2x5/8 bronze bushing. The housing needs to be machined to 5/8 first. When done with new thrust bearings and spring it will work like new again with throttle response again.
