Posted by Dan Oehmke on October 09, 2007 at 18:43:23 from (71.48.124.178):
How do I adjust the carb float on McCormick Deering 10-20? I checked the operator's manual and the overhauling 10-20 manual --- but nothing about setting floats. Does the bolt the float pivots on part of the adjustment? Or do I bend the metal bracket on the float?
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
