Re: switching from thermo-siphon system to water pump
Posted by Bob Kerr on October 09, 2007 at 20:52:55 from (205.188.116.73):
In Reply to: switching from thermo-siphon system to water pump posted by dennis repaal on October 08, 2007 at 10:23:42:
One thing I noticed on a thermosyphon engine it the head gets very hot abd the bottom of the block is cool enough to touch. There is a difference in a 10-20 thermosyphon head and a W-30 water pump head. The holes that go fron the block to the head and in the head are smaller on a water pump equipped engine. Thermosyphon needs more opening to let the hot water pass easier on its way "up". A water pump will push it too fast and it will run way too cool so they made the holes smaller on those. I would see if "C" head part numbers for one with water pump is different that a non water pump engine. Water pump equipped engines always run hotter water at the bottom of the block since the flow is pushed through.
