Re: Studs broke off in H block
Posted by Andrew Z on October 10, 2007 at 07:01:32 from (12.76.128.175):
In Reply to: Studs broke off in H block posted by PUTTER on October 10, 2007 at 06:55:09:
I have had pretty good luck with craftsman screw outs there a square shaped device that has groves on it. Iv also used easy-outs but have had better luck with the screw outs. you drill a hole in the middle of the stud adn then the screw out goues in there. Also alittle heat on the cast will help but dont want to heat that stud.
Andrew
