Re: Studs broke off in H block
Posted by Steven f/AZ on October 10, 2007 at 08:09:28 from (216.67.213.217):
In Reply to: Studs broke off in H block posted by PUTTER on October 10, 2007 at 06:55:09:
I have had luck blasting them out with a cutting torch. Usually just have to do a quick clean up with a thread chaser... but once had to drill oversize and put in a heli-coil.
Welding a nut on may work as well - use the impact wrench on it, the vibrations work the rust loose.
