Re: Stupid Question...Add Oil Where?
Posted by neblinc on October 11, 2007 at 06:53:52 from (24.123.122.114):
In Reply to: Stupid Question...Add Oil Where? posted by Salmoneye on October 11, 2007 at 06:48:13:
That is correct, there are "ears" on that cap. Be careful removing it, if it is tight, they can break off.
Fill till oil come out the top petcock on the oil pan.
Randy
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
