John M - Usually a "self exciter" is a standard 3-wire 10SI alternator retrofitted with a different internal regulator to render it self-exciting.
As the others point out, most self exciters need to be spun up to a considerably higher RPM before they'll begin to charge. (However once they start charging they'll continue to charge atlow RPMs same as a 3 wire unit.) There are however "low cut-in" self-exciting units out there - but I've had no experience with them.
Also all self-exciters I've seen pull a small amount of current (on the order of milliamps) when shut down. Generally this leakage current is not a problem - it's usually less than a good battery's self discharge rate.
However I've run across a couple self-exciters that drew so much standby current they would flatten a fully-charged battery in a matter of a week or so.
I'm not particularly fond of self exciting alternators myself....
Today's Featured Article - Listening to Your Tractor - by Curtis Von Fange. Years ago there was a TV show about a talking car. Unless you are from another planet, physically or otherwise, I don’t think our internal combustion buddies will talk and tell us their problems. But, on the other hand, there is a secret language that our mechanical companions readily do speak. It is an interesting form of communication that involves all the senses of the listener. In this series we are going to investigate and learn the basic rudimentary skills of understanding this lingo.
... [Read Article]
Latest Ad:
[More Ads]
