Re: Schwartz Wide Front
Posted by Tim Shaw on October 11, 2007 at 12:05:35 from (66.241.183.202):
In Reply to: Schwartz Wide Front posted by ScottyHOMEy on October 10, 2007 at 06:50:32:
ih560 said: (quoted from post at 00:47:42 10/11/07) The Heavy duty Schwartz has larger spindles. All the schwartz front ends, were made to work with the factory hubs. If you had the large cast centers you could reuse those on your front end, or if you had 6 lug hubs you used those on your front end. The hubs had nothing to do with whether it was Heavy duty or not. I just put a schwartz wfe on my 560 and you just take the hubs off the narrow front and put them on the wide front.
The heavy schwartz front end does come with hubs. Look at the pdf file in the following link.
http://www.aisalesrep.com/pdfretail%5Cag/schwartz.pdf
