If it moves at all, it can be pretty simply doctored up by using penetrating lube on it (auto trans fluid is good) then working it in out 1/8" and around and around till it gets loose. Flush the casting and rod with lube till the dripping comes clean on the other side, leaving rust in the casting will wear it out radically. If it is stuck, I would put the crank on the snout with a 75# weight on the handle pulling down. Then I would heat the shaft where it enters the bolster (not red hot, but dang hot, then let it cool) do this for three or four times, then let it cool till cold. Tapping on the end and continuing to pull, is about the only way. JimN
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
