Re: Motor in F12--F14
Posted by Fawteen on October 11, 2007 at 14:37:27 from (75.104.128.59):
In Reply to: Motor in F12--F14 posted by Marvin KY on October 11, 2007 at 14:07:56:
The only significant difference between and F12 and an F14 motor is that the governor on the F14 is turned up 200 RPM over the F12 (1650 vs. 1450, IIRC)
There are some other minor differences such as the routing of the valve cover breather, but mechanically they are identical and all parts will interchange.
I believe there are some "gas only" heads out there that will give you a little better compression than the distillate heads, but I don't have any numbers handy.
