Re: Motor in F12--F14
Posted by Andy Motteberg on October 11, 2007 at 14:49:04 from (4.143.219.72):
In Reply to: Motor in F12--F14 posted by Marvin KY on October 11, 2007 at 14:07:56:
The F-12 and F-14 heads look the same, but they have a different part number, so they must be different. The number on a F-12 head should be 3195-D. The block is the same. The F-12 & F-14 oil pump is also different, the F-14 has a float to float on top the engine oil, it takes in cleaner oil that way. The push rods and valves will work from a F-12 to a F-14. They both use the same IHC carburetor, AC fuel pump and IHC magneto. The F-14 has a tighter governor spring so the F-14 runs at a higher RPM.
