rret: Probably 99.9% of all intended uses on 3 point hitch requires no down presure. In fact most 3 point hitch implements would be damaged by tractor weight when going over uneven ground. The items that wouldn't be damaged like plows, disks, rear blades, etc. would lift the tractor's rear wheels causing it to loose traction.
I expect one could argue have down a down presure position on hydraulic control, and if that were the case it would probably be necessary to tripple the weight of 3 point linkage to withstand tractor weight. Couple that with the fact factory 3 point hitches are draft controlled and probably represent close to 12% of the total cost of the tractor. The 3 point hitch was designed as a precission control hitching tool, not a jack for lifting the tractor.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
